Simple automatic zigzagger Z-3
Simple automatic zigzagger Z-3  Empty Simple automatic zigzagger Z-3
Message par RLDWF le Lun 25 Jan - 13:11
Bonjour à tous.
En regardant avec quoi j'allais pouvoir remplir le plateau de la featherweight de madame, je suis tombé sur ce petit zigzagger sympa.
De mémoire il fonctionne, la notice est en anglais mais ce n'est pas un obstacle, et il s'adapte sur toute machine low-shank.
Je me demande qui a bien pu le fabriquer, je n'ai relevé aucun indice sur la boite, sur l'appareil, ni la notice et google semble plutôt mal informé. On le trouve mais sans plus sous firefox.
Simple automatic zigzagger Z-3  DSC02548_zps7hvftjey
La notice est tout ce qu'il y a de laconique :
Introduction :
This simple and modern attachment converts your straight sewing machine to do the work of more expensive zigzag sewing machines.
There are no parts to change on your sewing machine. Just attach the automatic zigzagger to the presser bar and you will be able to get a variety of pattern sewing by merely setting the pattern selector slide pannelto the desired pattern index. The zigzagger does the rest.
How to attach the zigzagger :
Remove the presser foot of the sewing machine and lift needle bar.
From rear of presser bar, guide zigzagger so that the fork arm of the zigzagger stradles the shank of the needle clamp and secure it onto the presser bar by securely tightening the presser foot screw.
Selection of patterns :
Depress key lever on the right side of the zigzagger and simultaneously slide the pattern selector slide pannel to the desired pattern index and release key lever.
Notes :
By adjusting the stich length, you will be able to get a variation of patterns.
By sewing on thin material, back cloth up with paper sheet. The paper sheet acts as a reinforcement and you will be able to sew easily on thin material and get a better finish.
After sewing, cut out the paper back but be careful not cut the thread.
